付费版EPIM Pro 7.0几个问题和建议
中文语言的讨论和支持
kevin
Post by kevin »
Hello Sir
我用最新付费版EPIM Pro 7.0,有以下几个问题:
1. 当有多个数据库并且设置了密码保护时,启动EPIM会提示输入密码,但是因为标题栏太短,无法知道当前打开的是哪个数据库。希望改进。
http://screencast.com/t/jykTh9vB
2. 修改某个密码项Add/Delete Field时是为什么会把所有密码都给改了,这非常让人困扰。而且这个动作没法恢复。希望改进。
http://screencast.com/t/XLw4WKJdD
3. 备忘录无法复制带格式的文本(如表格),只能复制纯文本。导出到其他地方(如word或邮件)时不方便。希望改进
http://screencast.com/t/LQOYBEJXlm
PS: 我把截图放到附件里,以上链接不一定能访问到。
谢谢!
1。当有多个数据库并且设置了密码保护时,启动EPIM会提示输入密码,但是因为标题栏太短,无法知道当前打开的是哪个数据库。希望改进。
2。修改某个密码项Add/Delete Field时是为什么会把所有密码都给改了,这非常让人困扰。而且这个动作没法恢复。希望改进。
3。备忘录无法复制带格式的文本(如表格),只能复制纯文本。导出到其他地方(如word或邮件)时不方便。希望改进
kevin
Re: 付费版EPIM Pro 7.0几个问题和建议
Post by kevin »
Hi, Max
我是终生付费用户,这几个问题没人解答吗?已经发了两周了吧!?
谢谢!
Dear TerryRogers, Max
Have you seen the problem I reported, could you help to resolve it ASAP ?
As a registered EssentialPIM Pro user, I expect to receive priority support on my inquiry. As you said "The fastest and the easiest way to resolve issues, is to post a message in the Support Forum. Our support personnel regularly check for new messages."
EthanGuo
Post by EthanGuo »
到这里支持一下h'h :D :D :D :D :D :D :D
Please use latest version, which is by now 7.51
kevin
Post by kevin »
I tested with latest version 7.52, #1 not fixed, #2 fixed, #3 fixed.
Thank you! Please continue to fix the #1 issue.
there is nothing to fix, window is small and it's OK if the whole path does not fit. We will no be increasing the size of the window.
kevin
Post by kevin »
Max wrote: Tue Aug 08, 2017 10:50 pm Hello,
Hello, Max
Could you show tool tip when mouse hover the title, so that I can see full path of database.
Thanks!
Thank you, noted.
kevin
Post by kevin »
Dear Max,
I am using v7.54, whenever remove fields in password, it will remove fields of ALL password entries, it is very bad. I hope to have option allow me to add/delete fields in single password entry, instead of ALL!
How do you think of it?
Best regards!
Kevin 2017-11-7
Hello Kevin,
this is by fundamental design. So far we have no plans to change it, though you suggestion is noted.
