Data Base Disappeared
Hi. I started the program and I think (not sure) I may have hit some type of keystroke because instead of opening with the EPIM Today list so I could select Calander, I got the message that there was no data base and I should double click to select one. I have no idea what I did. Any suggestions? I'm have been successfully using the program (7.24) right up until today on my Windows 10 system. Appreciate any help you can provide. Alan
Re: Data Base Disappeared
Most likely you closed the database. Please use File-> Menu- that might be showing the last opened files in the menu. If your database is still not there, search your computer for *.epim files and one of them will be your original database.
