I have few categories in the contacts.
My Contacts
Cat a
Cat b
List B
When I tried to search for a contact in List B from the "My Contacts" (root) it shows. But when I try to search from Cat b or Cat a
it doesn't. This is a major flaw. A contact should be searchable from all categories above it hierarchy.
At least you should allow an option for the user to enable this kind of searching
Major problem with Contacts search
Re: Major problem with Contacts search
it is by design- searching in sub-folders. If you want to search all Contacts, you can always click on root folder.
