全選刪除電子郵件會出錯
中文语言的讨论和支持
fredlu
全選刪除電子郵件會出錯
Post by fredlu »
Code: Select all
Exception log with detailed tech info. Generated on 2016/2/20 下午 09:24.
 Application title: FREDLU.epim - EssentialPIM Pro
 Application file: D:\EssentialPIM Pro\EssentialPIM.exe
 Application: EssentialPIM Pro 6.57  2016/2/15
Exception message: exception 6
NOMAILFOLDER
MailFolder not exists
At trigger 'MESSAGES_BU0' line: 5, col: 107.
Exception address: 006750B8
Main thread ID = 12192
Exception thread ID = 12192
Object Logs:
724804015  SetViewMode OK
724663703  SetViewMode 5
724663125  DBOpen OK
724663031  SetViewMode OK
724661390  SetViewMode 0
724659156  DBOpen
724659156  DBClose OK
724656968  DBSave OK
724650812  DBSave
724650484  DBClose
724594031  SetViewMode OK
724589078  SetViewMode 7
724581515  DBOpen OK
724577906  SetViewMode OK
724573000  SetViewMode 0
724544421  DBOpen
726728281  ExceptionDialog TextMemo
726718390  MainForm FormPan FormPan2 MailForm MessagesPan MsgListPnl MessagesVT
726595359  ExceptionDialog OkBtn
726594281  ExceptionDialog TextMemo
726587203  MainForm FormPan FormPan2 MailForm MessagesPan MsgListPnl MessagesVT
726567625  MainForm FormPan FormPan2 MailForm FoldersVT
726555625  MainForm FormPan FormPan2 MailForm MessagesPan MsgListPnl MessagesVT
726489062  ExceptionDialog DetailsMemo
726487062  ExceptionDialog DetailsBtn
726484531  ExceptionDialog OkBtn
Last Clicks:
726728234  TBXItemClick: MainForm FormPan FormPan2 MailForm MessagesPM TBXItem10
726726000  ShortCutAction: MainForm FormPan FormPan2 TodayForm SelectAll
726724875  MouseClick: MainForm FormPan FormPan2 MailForm MessagesPan MsgListPnl MessagesVT
System   : Windows 8 Workstation, Version: 6.2, Build: 23F0, ""
Memory: 8165; free 4977
Display  : 1366x768 pixels, 32 bpp, 96 PPI
PrevExceptions:
726459609  exception 6
NOMAILFOLDER
726555578  exception 6
NOMAILFOLDER
726718015  exception 6
NOMAILFOLDER
Stats:
MenuClick: MainForm NavPanelPM TMenuItem  1
MouseClick: AboutForm OKBtn  1
MouseClick: ExceptionDialog DetailsBtn  1
MouseClick: ExceptionDialog DetailsMemo  1
MouseClick: ExceptionDialog OkBtn  2
MouseClick: ExceptionDialog SendBtn  1
MouseClick: MainForm FormPan FormPan2 MailForm FoldersVT  5
MouseClick: MainForm FormPan FormPan2 MailForm MessagesPan MessagePan Header2Pan  1
MouseClick: MainForm FormPan FormPan2 MailForm MessagesPan MsgListPnl  2
MouseClick: MainForm FormPan FormPan2 MailForm MessagesPan MsgListPnl MessagesVT  6
MouseClick: MainForm LeftPan NavPanel NavGroup5  1
MouseClick: MainForm LeftPan NavPanel NavGroup7  1
MouseClick: MainForm LeftPan NavPanel NavScroll RightPan AddBtn  1
MouseClick: OptionsDialog ApplyBtn  2
MouseClick: OptionsDialog ContentsVT  10
MouseClick: OptionsDialog OKBtn  2
MouseClick: OptionsDialog PageControl1 GeneralTS GroupBox2 StartModuleCB  2
MouseClick: OptionsDialog PageControl1 GeneralTS ShowPrivateCB  2
MouseClick: OptionsDialog PageControl1 MailTS MailShowGridCB  1
ShortCutAction: MainForm FormPan FormPan2 TodayForm SelectAll  2
TBXItemClick: MainForm FormPan FormPan2 MailForm FoldersPM FolderSyncMI TBXItem22  1
TBXItemClick: MainForm FormPan FormPan2 MailForm MessagesPM TBXItem10  4
TBXItemClick: MainForm TopPan TBXToolbar1 HelpMI HelpAboutMI  1
TBXItemClick: MainForm TopPan TBXToolbar1 ToolsMI ToolsOptionsMI  2
Updates: 1
Last update: 2016/2/20
Re: 全選刪除電子郵件會出錯
looks like it is an IMAP account. You can delete it and create again- should fix the problem.
fredlu
Re: 全選刪除電子郵件會出錯
Post by fredlu »
Max wrote:Hello,
嗨~
我重新建立後 還是一樣
郵件可以全選嗎?
Re: 全選刪除電子郵件會出錯
Please post a screenshot of all folders in your mail account. Also, can we get a test account on the same server? We need to test and reproduce the issue.
