Please be aware that this is the place to discuss (and submit) iCals, but not the one to download them from. If this was what you wanted, go to
http://www.essentialpim.com/?r=download&pr=ical instead.
Also, if you're not logged in as a member, you will not see the upload window and will not - understandably - know what is going on. It might be very confusing.
Sorry about that!
If you are not a logged in member, PLEASE READ.
- Has thanked: 33 times
- Been thanked: 14 times
Re: If you are not a logged in member, PLEASE READ.
Clicked on the link above while logged in, but didn't see any ICAL info.
EPIM Android Pro v5.7.4 -Samsung Galaxy S5(SM-G900V) - Android OS v5.0
EPIM Portable Pro V6.0 RC2 - Windows 7; XP
EPIM Desktop Pro V8.64 - Windows 7
- Has thanked: 820 times
This was a very old topic, as you can see. You can google for iCal and import them into EPIM.
Thanks Max. Have had some success with holidays. Sure beats manually entering them!
