Hi
i 'm running essentialPim free 6.52 , i installed the last version of essential pim for android
and i got always the same error "unable to connect to the server ,check firewall settings...."
disabled and uninstalled eset smart security , disabled w7 firewall
here my steps by steps , both my pc and my phone are connected to the same router
1)
2)
3)
now i go to my mobile -> essential pim ->sync -> i can see the name and 192.168.0.3:21114 match ,are the same on my device
can you please help me?
can't sync to my android , can you help me please?
- Has thanked: 1418 times
Re: can't sync to my android , can you help me please?
Looks like you're doing everything correctly. Please see here for more tips: http://www.essentialpim.com/help/index. ... oting2.htm
If it still doesn't work, please try alternative connection methods: http://www.essentialpim.com/help/synchr ... _cable.htm
- Has thanked: 7 times
- Been thanked: 2 times
hiadmin wrote:Looks like you're doing everything correctly. Please see here for more tips: http://www.essentialpim.com/help/index. ... oting2.htm
i was able to do it
i 'm geting the essential pim pro , is amazing , but can't i set a password to access to essential pim for android?
i don't know if it's better EssentialPIM Pro (Desktop/Portable) $39.95 or EssentialPIM Pro lifetime license $79.95
by the way , it's insane that after $79.95 , i should pay for the android pro version too
Great, glad you made it working. Password for the whole app is available only in the Pro Android version.
Lifetime license is better if you plan to use the program for more than couple of years and prefer to have the latest version available at your disposal. Keep in mind Android EPIM Pro license is the lifetime one, as well. Thanks!
I can only sync after manually turning off my Windows Firewall on my computer. This is a lot of trouble and a security hazard.
Two questions:
1.Does the app error message, "Check firewall settings on your computer" actually mean "Turn off firewall"?
2.What is the firewall setting that would allow sync without disabling the firewall completely?
Thank you.
Two questions:
Thank you.
Windows firewall divides your connection into 2 different parts:
- private networks
- public networks
Please make sure you enable incoming connections for EssentialPIM (Advanced settings->Inbound rules) as for private as for public networks. Or you can delete the existing rule, restart EssentialPIM and create a new one.
- private networks
- public networks
thanks in lateadmin wrote:Windows firewall divides your connection into 2 different parts:
- private networks
- public networks
but yes i had this problem
thank you so much , really very appreciate it
