How to assign item access ?
Hi, Our company need a pim note for teamwork and management. We are evaluating the Essentialpim network version. We tried and found it easy to use. But we feel hopeless when trying the fuction of "assigning access to items to specific users". The manual says :“If we want to assign access to this item to specific users, let's press the "..." button. ” But we cannot find that"..." button at all. Please tell us why and how.
Looking forward to your early reply.
Win8 5.57 network trial ver
Re: How to assign item access ?
please have a look at attached screenshot.
First of all, login with SYSDBA:masterkey and create at least 2 users.
Then, login with one of the users and press the "..." in "Status" field, see screenshot. There you can assign which users have access to the item.
login with SYSDBA:masterkey or other users still cannot find that button, see the image below...
am i using wrong version?
no "custom" status appear, and no ... buttonam i using wrong version?
i created several database to test again and again, and i see custom stuatus now, but still no ... button
the custom status disappear again...
I suspect...you compiled the wrong version for the networking!
I have sent you a Private Message with a temporary license code that will enable this feature.
Hi, i installed EssentialPIM Network today to try out the tasks shared. I need to assign tasks to specific users.
Can I get a temporary code for evaluation?
Thank you.
Thank you.
OK, have sent you.AbacoElaborazioni wrote:Hi, i installed EssentialPIM Network today to try out the tasks shared. I need to assign tasks to specific users.
Thank you.
dear Max
i tried your temp reg code and still not working please check your version is alright
Everything is correct. Now you can see the "..." button in "Status" field.
