Server login problem
Chris M
Post by Chris M »
Hi I have the trial network version & when I connect to the server the program seems to lockup, if I use a local copy of the database Epim works ok.
The Firebird server is running on Linux, I know it's configured correctly because I can connect to the Epim database on the with another program called TurboBird running on the win 7 machine that Epim won't work on.
Any suggestions?
Re: Server login problem
Try creating a new database and connecting to it for a test.
Chris M
Post by Chris M »
I tried that & with a local copy of the database it works fine, but if I take the same database & move it to the server it won't work, I forgot to mention, briefly I get a message saying that my database file need consistency checking, but other than that the program locks up.
So you are using non-Windows server for Firebird? We can't provide support for this, but one hint would be to check you are running exactly the same version of Firebird that we provide for Windows version.
