Hello My epim says that there is no outlook installation. I work with microsoft outlook 2000. no 64bit.
How can I say to epim where it can find the outlook installation ?
I am using the epim professional portable version. Where epim is looking for the installation.
Because if you install outlook not where its normally is, epim cant find it.
Thank you
Ciao
Roland
Outlook Sync epim cant find it
Re: Outlook Sync epim cant find it
you can not tell EPIM where to find outlook installation. It also looks for certain Office system files, not for concrete Outlook location.
Unfortunately there is not much we can do, to be honest. You can of course, try reinstalling Outlook.
