I have big Problems to sync with Memotoo and i get no answer. See:
viewtopic.php?f=14&t=13009
So i tried the Android-App.
Ok. it works well, but the Pictures of my Contactentrys are not synchronized.
In both directions the synchronization of the Pictures does not work.
Is this a known problem?
regards Erwin
Sync EPIM5.03PRO with Android
- Has thanked: 1418 times
Re: Sync EPIM5.03PRO with Android
Pictures of contacts aren't currently synchronized. This feature will be added in the next version of EPIM. Thanks.
