when I want to sync with my iphone, it fails
Re: when I want to sync with my iphone, it fails
What happened is you upgraded your iOS and something broke.
We need screenshots of course in order to help.
You can try deleting synchronization and creating it again through Wizard.
- Has thanked: 25 times
- Been thanked: 11 times
hello!
thanks for your answer
I just have a window on my iphone with " connection failed" that's all !
what is WIZARD ? I've been on google and saw it was a game !
I already try a few times to delet synchronisation in EPIM in my pc, but it didn't change anything
did you mean on the iphone ? how can I do that ?
do you think I can delet EPIM on my iphone and then re-load it on itunes ?
thanks
nathalie
thanks
nathalie
Please read Help file here:
http://www.essentialpim.com/help/ios_iphone__ipad.htm
hello!
thanks for the link I already went there but it didn't help me
I have deleted epim app on my ifone and then reinstalled it
then I deleted synchronisation on my epim and now it is impossible to add it again !!
I have this window ( sorry screen shot does not work on my pc , I can send you a photo on PM)
Pair device in 3 simple sets. after Epim will remember the settings;
make sure your ios device is connected on the same network as yoyr pc
etc ..
then
if it does not work
-make sure you have itunes installed on your pc
check that ios device and pc use the same (wifi) network
try changing port number : 21108 change
ALL is OK, but it stpos there, I can't go further!
Ios can recognize my pc, but I cannot enter the settings again in EPIM pc ....
what's wrong now ?????????????
thanks !
etc ..
then
if it does not work
thanks !
All the possible problems are described here:
http://www.essentialpim.com/help/troubl ... hroniz.htm
There is solution, to find the problem, like it is described in Help file.
but all is ok !
I did it
all seems to be ok, except that it does not work !! ??
I did it
Hi!
I tried the last couple of days to sync my epim database with my iPhone.
The last sync I did was about a month ago and it worked well.
Now I get an error in SyncForm and my iPhone is „Successfully disconnected.”
Do you know why this happens and what I have to do to make it work?
Thanks!
Thanks!
- Error.jpg (32.41 KiB) Viewed 13227 times
try to synchronize a new, empty EPIM database- will it sync?
i also had this problem.
i tried all that things that mentioned here, but nothing solved the problem.
so i tried another thing that fix the whole problem.
i dont know if this is the same problem, but i downloaded and installed icloud on windows, loged in to my apple account, and when i tried to get in to pc sync at my iphone it worked.
try it out and klet me know if it helped.
