hello,
when I import a .isc file,
an error windown came up with following information:
This iCal file can't be imported because some parts of it are not iCal compliant. Please check with the vendor of the software that produced the file.
Strangely, I can use Outlook 2007 to open it.
My version is 4.01port,
Please check it.
Thank u!
ics import problem
- Has thanked: 820 times
Re: ics import problem
we need your ics file to check you. You can send it to ma@essentialpim... WITH a link to this topic. Thank you in advance.
Hello, Max,
Since my mailbox doesn't work properly, I'll put the content in this post.
Some of important information are replaced with xxx or XXX, and the whole structure is like following:
BEGIN:VCALENDAR
PRODID:-//Microsoft Corporation//Outlook 9.0 MIMEDIR//EN
VERSION:2.0
METHOD:REQUEST
BEGIN:VTIMEZONE
TZID:(GMT+01:00) Amsterdam\, Berlin\, Bern\, Rom\, Stockholm\, Wien
BEGIN:STANDARD
DTSTART:20101031T020000
RRULE:FREQ=YEARLY;INTERVAL=1;BYDAY=-1SU;BYMONTH=10
TZOFFSETFROM:+0200
TZOFFSETTO:+0100
TZNAME:Standard Time
END:STANDARD
BEGIN:DAYLIGHT
DTSTART:20100328T030000
RRULE:FREQ=YEARLY;INTERVAL=1;BYDAY=-1SU;BYMONTH=3
TZOFFSETFROM:+0100
TZOFFSETTO:+0200
TZNAME:Daylight Savings Time
END:DAYLIGHT
END:VTIMEZONE
BEGIN:VEVENT
ATTENDEE;ROLE=REQ-PARTICIPANT;PARTSTAT=NEEDS-ACTION;RSVP=TRUE;
CN="xxx@xxx":
MAILTO:xxx@xxx
ORGANIZER:MAILTO:XXX@XXX
DTSTAMP:20111108T093721Z
DTSTART;TZID="(GMT+01:00) Amsterdam, Berlin, Bern, Rom, Stockholm, Wien":20111026T123000
RRULE:FREQ=WEEKLY;UNTIL=20120327T220000Z;INTERVAL=1;BYDAY=WE;WKST=SU
DTEND;TZID="(GMT+01:00) Amsterdam, Berlin, Bern, Rom, Stockholm, Wien":20111026T150000
TRANSP:OPAQUE
SEQUENCE:0
UID:303127_8000181760_0
DESCRIPTION: XXX
\n
XXX\n
XXX\n
\n
XXX\n
\n
\n
\n
SUMMARY:XXX
PRIORITY:5
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:PT15M
ACTION:DISPLAY
DESCRIPTION:Reminder
END:VALARM
END:VEVENT
END:VCALENDAR
I've checked that a isc file with above modified contents still doesn't work in EPIM, by contrast it does work in Outlook.
please check whether such imformaion is sufficient for analysis.
Thank u!
BEGIN:VCALENDAR
VERSION:2.0
METHOD:REQUEST
BEGIN:VTIMEZONE
BEGIN:STANDARD
TZOFFSETFROM:+0200
TZOFFSETTO:+0100
END:STANDARD
BEGIN:DAYLIGHT
TZOFFSETFROM:+0100
TZOFFSETTO:+0200
END:DAYLIGHT
END:VTIMEZONE
BEGIN:VEVENT
CN="xxx@xxx":
MAILTO:xxx@xxx
TRANSP:OPAQUE
SEQUENCE:0
DESCRIPTION: XXX
\n
XXX\n
XXX\n
\n
XXX\n
\n
\n
\n
SUMMARY:XXX
PRIORITY:5
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:PT15M
ACTION:DISPLAY
END:VALARM
END:VEVENT
END:VCALENDAR
Thank u!
