Bug with hyperlink
solstis
Bug with hyperlink
Post by solstis »
Epim portable PRO V4.01
Hi Max,
There is a bug when I want to insert an hyperlink in a appointment.
Best regards.
Toolbar item index out of range.
Exception log with detailed tech info. Generated on 04/01/2011 22:50.
Application title: temp.F378C027.epim - EssentialPIM Pro Portable
Application file: D:\PRIV\PIM\EssentialPIM.exe
Application: EssentialPIM Pro Portable 4.01
Exception class: ETBItemError
Exception message: Toolbar item index out of range.
Exception address: 00507724
Main thread ID = 2952
Exception thread ID = 2952
Object Logs:
620109 TTask Change 271226479950820938
619937 TTask Change 253362538828125455
609015 TToDo Store 335403300091201869
609000 TToDo Change 335403300091201869
596812 TToDo Store 305497616106995880
596765 TToDo Change 305497616106995880
640312 ExceptionDialog TextMemo
636500 HyperlinkDialog OKBtn
627500 TaskDialog TntPageControl1 TaskTS TntGroupBox1 TextMem RichViewEdit
626500 TaskDialog TntPageControl1 TaskTS TntGroupBox1 EndTimeDTP
620500 TaskDialog TntPageControl1 TaskTS TntGroupBox1 TitleEd RichViewEdit
614500 MainForm FormPan FormPan2 TasksForm DayViewDP
612578 MainForm
609500 MainForm FormPan FormPan2 ToDosForm ListsTC ToDosVT
607593 ToDoDialog TntPageControl1 ToDoTS TntGroupBox1 TitleEd RichViewEdit
600921 MainForm FormPan FormPan2 ToDosForm ListsTC ToDosVT
Call stack for main thread
Stack list, generated 04/01/2011 22:50
(0000D514){ntdll.dll } [7C91E514]
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 3"
Memory: 2037; free 1471
Display : 1280x800 pixels, 32 bpp
Re: Bug with hyperlink
Can you reproduce that on a new database? If yes, what are the exact steps? Thanks!
Lee S
Beta Team
Been thanked: 30 times
Post by Lee S »
Hi Max
Got a similar error on Epim Portable. Noticed yesterday on 4.0 b4 upgrading to 4.01. Reinstalled in a fresh folder and used the original DB. Problem went away. Maybe an old file didn't overwrite successfully.
Lee S
solstis
Post by solstis »
Thank you,
I do not understand why but it works.
Best regards.
nunoleite
Been thanked: 8 times
Post by nunoleite »
Hi!
I'm having exactly the same problem after upgrading from Portable Pro 3.23, to 4.01.
I think i found the bug.
It just worked with a new and empty database.
But there is another thing, just after i disable a module, it just gives the error.
I usually disable email module cause i don't use it. So if there is a module disabled, the hyperlink just don't work.
Hope you can fix this.
Nuno Leite
nunoleite
Post by nunoleite »
Hi!, Again,
I confirm this.
After enabling all the modules the error disappears.
So the bug is confirmed.
Waiting for the fix........
Nuno Leite
How did you insert a hyperlink? Into which field? A detailed list of steps would be appreciated. Still couldn't reproduce after disabling couple of modules.
nunoleite
Post by nunoleite »
Hi!
I will do a guide step by step:
- Downloaded file EssentialPIMProPort4.zip
- Uncompress to "O:\Automatico\EssentialPIMPro"
- Run EssentialPIM.exe
- Insert my registration
- Choose English
- Asking to import from outlook and outlook express, and choose no.
- I have now your test.epim opened
- I'll go to calendar
- Add appointment
- Put the cursor on notes and press Hyperlink button
- Choose Item link and browse
- it shows the window to select another item
- i selected and it worked
- Now i will go to options and disabled Mail and Password modules
- again in calendar
- add appointment
- put the cursor on the field Notes
- press the hyperlink button
- choose Item Link and browse
- It gives this error
The application might become unstable and even useless.
It's recommended that you save your work and close this application.
Exception log with detailed tech info. Generated on 11-01-2011 13:42.
Application title: test.epim - EssentialPIM Pro Portable
Application file: O:\Automatico\EssentialPIMPro\EssentialPIM.exe
Main thread ID = 4324
Exception thread ID = 4324
Object Logs:
341092281 TTask Change 228686969084246016
341092046 TTask Change 225253357198937600
341092031 TTask Change 225253357198937600
341090859 TToDo Change 307667915538457088
341090859 TToDo Change 311548027730492928
341090828 TTask Change 216504898915505664
341090828 TTask Change 244964088052013056
341090828 TTask Change 274103204030453760
341130578 ExceptionDialog TextMemo
341128453 HyperlinkDialog OKBtn
341094453 TaskDialog TntPageControl1 TaskTS TntGroupBox1 TextMem RichViewEdit
341092468 TaskDialog TntPageControl1 TaskTS TntGroupBox1 TitleEd RichViewEdit
341049578 MainForm
341048484 OptionsDialog
341047453 OptionsDialog TntPageControl1 ModulesTS ModulesCBL
340999906 OptionsDialog ContentsVT
340990453 MainForm FormPan FormPan2 TasksForm DayViewDP
340989468 TaskDialog OKBtn
Stack list, generated 11-01-2011 13:42
(0000D514){ntdll.dll } [7C90E514]
System : Windows XP Professional, Version: 5.1, Build: A28, "Service Pack 2"
Memory: 2047; free 1890
Display : 1024x768 pixels, 32 bpp
After this i re-enabled the all the modules and the error disappears.
So what i can understand from this is that maybe the program is search on disabled modules and because they are disabled he can't show it's items.
Hope you can reproduce this and find the bug.
Nuno Leite
Yes, was able to reproduce it this time. Thanks very much for your help!
