Insert Date/Time - Outline Collapse / Expand
ClearlyRobert
Post by ClearlyRobert »
I am new to EPIM PRO...gave up my 10 year old ECCO Pro since it wouldn't work well with Win 7....two things it did, I can't find how to do in EPIM: insert date and time in contact notes..and a way to set up an outline that collapses or expands in notes. These were great features in ECCO...is there someway in EPIM? CTRL D and T seem to only work in Notes. With ECCO, CTRL Q inserted both.
Speaking of which....it is a hassle that you can't use CTRL D and T on an old note...also, if you insert date and time, is there some way to set a default format so you don't get the dialog prompt for format each time?
TIA
