How to create and use Ical Calendar with Epim ?
salcedok
Post by salcedok »
Max, I have been testing V2 RC1 and the problem stil exists. What build will include the fix?
salcedok wrote:Max, I have been testing V2 RC1 and the problem stil exists. What build will include the fix?
The bug was reported after RC 1. The fix should be in forthcoming RC2
clauderenaud
Beta Team
Post by clauderenaud »
I'm looking for updated french calendar.
Does someone know where could I find a fresh one for 2008 and even for the upcoming years ?
regards,
Claude Renaud
gui
Post by gui »
clauderenaud wrote:I'm looking for updated french calendar.
Claude,
Perhaps something for you:
http://icalshare.com/index.php?topic=holidays
Gui
clauderenaud
Beta Team
Claude,
Thanks but I can not find a full calendar there, just for one department...
regards,
Claude Renaud
gui
Post by gui »
Claude,
And here?
http://www.addadate.com/frenchholidays2 ... index.html
Gui
clauderenaud
Beta Team
gui wrote:
clauderenaud wrote:
gui wrote: Claude,
And here?
Thank a million !
I downloaded the outlook .ICS file and will try to import it in epim ...
I kept the address for a later time ...
Thank again !
regards,
Claude Renaud
clauderenaud
Beta Team
Re: How to create and use Ical Calendar with Epim ?
Hi all,
I looked for on addadate but found nothing....
Does someone know if it exists a french calendar with all catholic celebrations ? (fêtes en français)
regards,
Claude Renaud
joshuafrfld701
Post by joshuafrfld701 »
Max that is part of the problem. I have tried to create an example of the iCal file by exporting from tasks/ToDo lists with alarms and I can not find the alarms in the output iCal file. There is no line item that shown that an alarm has been set.
___________________________
wall calendar
I just created a sample ToDo with a reminder.
Here is what I got:
BEGIN:VCALENDAR
VERSION:2.0
CALSCALE:GREGORIAN
METHOD:PUBLISH
BEGIN:VTODO
UID:302648893322638530
LAST-MODIFIED:20091120T231519Z
SUMMARY:ss
CLASS:PUBLIC
DTSTAMP:20091120T231533Z
BEGIN:VALARM
TRIGGER:20091120T232000Z
ACTION:DISPLAY
END:VALARM
END:VTODO
END:VCALENDAR
Look at "VALARM" tag- its the Reminder.
