Increase View Space of EPIM
Hey,
Just wanted to give a quick tip, I was getting a lil annoyed of the small-screen size of the Notes pane (I have low resolution monitor)
Discovered that you can turn off the Navigation Pane, this opens up the Notes much more freely and looks like the way it was intended to look... just go to View->Navigation Pane to turn it off.
To navigate now, just use CTRL+0 - CTRL+7 (I changed mine to ALT), or Go->Panel
Pretty cool...
Pretty cool...
My blog about How to Get Rich
