Work around for Google transfer
This is not very pretty but it does get the job done. It takes a few steps (I can't wait for the day when we can subscribe to a google calendar, it would be very helpful.
First you have to export your Google calendar. Here are the instructions straight from Google:
To export your calendar content, just follow these steps:
1. Under "Calendars" in the left column, click on the down-arrow button next to the appropriate calendar, then select "Calendar settings." (Alternatively, click on "Manage Calendars" under "Calendars" in the left column, then click on the name of the appropriate calendar.)
2. Click on the "ICAL" button under "Private Address" and click on the displayed URL.
3. Save the exported file to the desired folder on your computer.
4. Following the instructions on the calendar application of your choice, import the file you exported from Google Calendar to the calendar application.
Now all you have to do is import your Calendar using the local file.
I have done this once and it worked OK. I will try again tomorrow to see if duplicates are enetered when I transfer the calendar.
Not the best way but it seems to get the job done.
I should say that it is about time. The following is promised on the front page of essentialpim.com since 2.2. was released if memory serves me right:Max wrote:Thank you. By the way, version 2.5 will feature full Google synchronization.
I did buy Epim long before I started use Google Calendar though, so this unfortunate wording doesn't affect me much - except, I really look forward to sync with Google Calendar. But had I bought Epim thinking it could sync with Google Calendar, I would not have been a happy camper.Synchronization with Outlook, Windows Mobile devices, Palm, iPOD, Google Calendar.
- Has thanked: 1 time
- Been thanked: 2 times
Re: Work around for Google transfer
Just tried the sync...
I have Separate calendars for "General", "Business", ect, and they are all visible when enable within Google cal...
EPIM only imported the entries that were in the "General" calendar...
Am I doing something wrong?
Thanks, Jake
Thanks, Jake
Hello, Jake,
during synchronization, EPIM works with the main calendar only so far.
Thanks Max!
By the way... wasnt complaining, just wondering if I was doing everything right!
Umm... I am asking this out of laziness, I apologize....
Is it theoretically possible to use the workaround described above to import my other calendars into EPIM?
Best, thank you,
-Jake
Best, thank you,
-Jake
