Palm sync in 2.0 RC1
I am looking for a way to do a palm sync in 2.0 RC1. Is this not yet included or how do I set it up?
thanks
thanks
No, unfrotunately. You will have to disable EPIM Palm sync. Palm OS designers made it very difficult to synchronize with Palm Desktop, EPIM, and Outlook at the same time...Linds wrote:thanks I was looking under file/sync
Can you have it sync with EPIM and with outlook at the same time?
Need more details.guest wrote:the portable version does not work. it does not sync with palm. i followed the instructions by max and nothing. i even updated the hotsync from my old sj22 sony to the new palm desktop to see if that was the problem. Nothing.
Please help. When will the portable beta version work with palm?
What is your hotsync version?
What is your Palm OS name?
Why do you think that "nothing happens"?
Do you see any error messages?
Which namely instructions you followed?
ok Max more details.
v 6.0.1
palmone palmdesktop software v 4.1.4
1. I run essentialpim pro portable v2.0 rc1
2. tools-->options-->Synchronization-->palm sync-->enable palm sync
database to sync: last opened file
database authorization: login:blank, password: blank, data password: blank
(no password in my palm)
sync options: all (schedule, notes, to do, contacts)
3. close essentialpimpro
4. run hotsync with my old palm IIIxe (infrared, which is enable in hotsync)
5. no problem sync with palm desktop
6. when I open essentialpim pro after sync, no information on my schedule, to dos, ect. (no sync)
no error messages.
What do you think?
v 6.0.1
no error messages.
What do you think?
I'm having the exact same issue!
Same as guest 5/2 12:18, except I'm using a Palm LifeDrive and I sync via USB.
please replace PalmSync.dll in your C:\Program Files\EssentialPIM Pro Beta\ with attached DLL- that will fix the problem.
- PalmSync.dll
- (205.5 KiB) Downloaded 400 times
