Kanban. Add Custom Column.
AJ
Has thanked: 50 times
Been thanked: 7 times
Post by AJ »
hi admin,
like kanban very flexible and also for personal kanban, you can add further columns.
i think i saw an example in book personal kanban or so.
you could also personalize / change names of columns.
if i oversaw this function pls say.
i maybe add later an example.
you propably use only 4 colums on laptop, but otherwise even more.
nice example for personal kanban with 7 columns, that should be enough.
you use 4th column today and you maybe need to change names of other, which is missing.
there is a nice example of a column 'recuring tasks', under all the other. great idea, but too complicated.
i would really appriciate adding columns and changing names, also of default.
thx
ps.
there is much potential on that, as missing sorting function and propably some other stuff.
Helps Make EPIM Great/No1!
Re: Kanban. Add Custom Column.
This is already in the backlog for future improvements to the Kanban view. Thanks!
