Cant Use System Theme! for consistent design and eye friendly!
hi admin,
pls try to add it in next minor vers if possible!
DARK THEME so BRIGHT is VERY ANNOYING!
even by low display brightness!
no idea if you have to write for each parameter use system...
or just one, like use system design/theme.
hi all betatester,
is there any progress in improving themes, i cant stand the bright dark theme with bright with letters!
its not only problem of inconsistency.
i dont want to get long, thx.
hi all betatester,
Helps Make EPIM Great/No1!
Re: Cant Use System Theme! for consistent design and eye friendly!
hi admin,
i have too many problems because of not having epim follow system theme.
it also prevents me using in first place a quite actual version.
it would solve a handfull of problems.
i also point out that daho2018 gave a thumb up in his 'other themes' thread on this idea.
i hope you can add a checkbox for simply following system theme very soon, as it makes me very few problems and leaves me very few versions behind.
i got also had a db issue, which cant be resolved.
its also quite much easier and more helpfull than making further themes and is kinda standard in good apps.
pls try to add this like a simple command if possible or copy all color settings and put follow system.
or let ai write it and just check.
no idea how far you use ai for coding.
i try to help as much as i can.
thx
thx
I believe this feature will be introduced in the next minor update of EPIM.
i try to reactivate an annoying mini fix in a minute, not here to not mix it.
yeah, maybe you can do 12.2.0.1 or 12.2.1 to quick fix.
thx, hope the idea of possibly efficient coding it and also idea of using ai generally, is nice fo you.
i try really hard to get the top 5 or 10 things epim still misses and are standard or can let epim overtake the standard and make the difference.
i would then knew if the bug not editing appointments the way i make, is gone.
hi admin,
very important! pls let toolbar icons color like is in dark theme, not follow systhem theme, like some good apps.
i had to adjust it kinda better.
maybe i can even quick fix the to bright text in epim dark theme before new version, as it prevents me long from main use.
hope i can adjust it maybe allready in dark theme, even if not so good as overtaken settings.
thx
thx
