MAX IMPORTANT Weather Info! Icons and Alerts, more inside...
hi admin,
i hope we can add some weather index, sunrise, sundown and maybe warnings.
i'm not sure what data the weather agencies gives, need to check.
would be important to get weather warnings, like the weather agencies show, like heavy storm, high temperature or ozon, smog, however.
i forgot the name for the index you should stay home or avoid direct sun.
however.
i you use your computer as communication center, but propably it would be also great impact, individualization to other apps, have the important on one look in your fav app, and overtake other pim apps.
i see also an advantage and convinience for phone, but not use one at the moment.
it will get even more important in the summer, like you can die because of the weather, even in very late summer before 12, like i lost some near relative not so long ago!!!
I would appriciate to see a red alarm with reminder asap as avilable, in epim, and warning icon in every module!!!
i would/will use only 5 apps when get phone, like you should not overload and one propably will do it, as of some coming technology. you should keep clean and lean.
THX!!!
however.
THX!!!
Helps Make EPIM Great/No1!
