Unable to use the programs or create new databases
Has thanked: 1589 times
Been thanked: 1085 times
Re: Unable to use the programs or create new databases
Ok, so you have the Portable version installed on your G:\ drive. Go to the EPIM folder, rename the EssentialPIM.exe file to something like EssentialPIM.bak and start EssentialPIM_Free.exe. Will there be issues with the Free version? If so, please forward us the detailed error logs from it.
poet-man
Has thanked: 13 times
Been thanked: 43 times
Post by poet-man »
@Katamaran
Did you ever try to install/run EPIM on a different PC?
In my opinion you should try, just to make sure there are no problems in hardware and/or software that is installed on it.
When was Windows reinstalled last time?
Katamaran
Post by Katamaran »
I have installed Epim on my other newer laptop, with windows 11, and there is the same problem, more or less.
poet-man
Post by poet-man »
Hardly any problems on Windows 11 over here.
Katamaran wrote: Wed Feb 12, 2025 1:55 pm I have installed Epim on my other newer laptop, with windows 11, and there is the same problem, more or less.
We've been working on improving stability and we'd appreciate it if you could try out the latest build (1032) by downloading and installing it from https://www.essentialpim.com/download/t ... ull121.exe. Let us know if it's more stable for you. Thanks!
Katamaran
Post by Katamaran »
I have completely formatted the hard drive and reinstall windows 10!
Today Epim works normally, so far.
We'll see how it will be in the future?
Hoping for the best!
Katamaran
Post by Katamaran »
This morning the programs stopped working again, according to the attached video.
It's really strange!
Before that I did is clear out all the junk mail that comes to my several email accounts.
Then suddenly the dialog box that cannot be turned off appears and the programs are blocked, cannot be used and cannot be closed??
Video_250217084840.mp4
(7.14 MiB) Downloaded 14 times
Katamaran
Post by Katamaran »
One more question: Is there a way in the mail module to create a new data file where you can collect all important mail from all email accounts?
I can't find it myself and I think it's really important to be able to do it in the email module!
There is currently All Inboxes but I want subfolders to be able to divide them.
As soon as I delete junk from any email account, the programs stop working and I can't use it!
Katamaran wrote: Mon Feb 17, 2025 8:55 am This morning the programs stopped working again, according to the attached video.
Could you please provide the EPIM build number you were using?
poet-man
Post by poet-man »
I wonder why nobody else seem to have that problem.
When reinstalling Windows 10, did you also install anything else or did you have a simple naked windows installation up to now, and nothing else?
Katamaran
Post by Katamaran »
It says Build 1030 EssentialPIM Pro 12.1.3
Why others don't have the same problem I have no idea but I wish you had this problem instead of me.
I have completely formatted the computer and then installed a clean Windows 10 x64. Then I installed all the updates.
Before we had an error in the notes module when you delete notes then the programs stopped responding.
Now the same problem is in the email module, if you delete junk mail then the programs stop responding. Having junk mail is not possible then it is not possible to use email at all.
Now the question is why the programs stop responding after deleting email (junk)?
Please refer to my post above and try the 1032 build, it should address the issues: https://www.essentialpim.com/forum/view ... 43#p137343.
Katamaran
Post by Katamaran »
I installed build 1032 and got the same error but I noticed that it usually comes from an email account so I removed it. Now let's see if it gets better?
