Application error
Application error
Hello!
It is not possible to use the programs because various application errors keep coming, as in the attached file, up which then cannot be turned off, but programs are only terminated with the task manager.
The program is unusable, at least for me.
Re: Application error
I create a new database and start over but it doesn't help until the program error comes up again?
- Has thanked: 1550 times
- Been thanked: 1061 times
How can we reproduce this issue on our end?
Hello!
In the next video you can see that the programs don't work, at least for me.
https://www.icloud.com/iclouddrive/096V ... %5F11%5F08
Have reinstalled it several times, created new database and nothing helps.
Would test with new access if you email it to me?
What is the new access?
When I bought the programs, I was given a username and password.
I would like to exchange them.
There is a license key for EssentialPIM but there is no username or password associated with it, unless you are referring to the EPIM Cloud service. If it is so, please provide your username or email address associated with the account.
Hello!
Thank you for your reply.
It says license name and license code.
As soon as I start the programs, a dialog box appears with program errors and it cannot be used anymore.
Maybe it got hacked or something.
Reinstalling it doesn't help; I've tried that several times without success.
Hello!
I have several categories in the contacts module.
If I want to delete a folder then the programs stop working according to the attached link.
https://www.icloud.com/iclouddrive/0a5z ... 0%5F130044
Please record a short video demonstrating the initial registration issue.
Regarding the second report, we confirm the bug and will address it in the next update. Thank you!
Hello!
I would look at mail but a message appears that the programs must be shut down, according to the attached video.
Sincerely
Sincerely
- Video_241202073436.mp4
- (7.68 MiB) Downloaded 51 times
If I have several email addresses, is it possible to change their order, ie move them up and down?
To rearrange your accounts in the Mail module, click Tools -> Manage Accounts. Then move your desired accounts up or down in the list and click Ok.
Hello!
According to the attached file, there is a new bug in the program: If you work with the local database, it is not possible to activate off mode, the answer is that you work with the database in Dropbox even if it is about the local database.
- Video_241209210440.mp4
- (1.82 MiB) Downloaded 39 times
This has been by design so far. However, we will explore the opportunity to make offline mode available even for database files located in Dropbox.
