Just to be sure ...
In Playstore it says, it is 6.0.17
At the same time it says (in my case) it's Beta.
So ... is v6.0.17 a beta or is it the latest final version?
And BTW
It's almost a year since there has been anything new to AEPIM?
Which version is it in PlayStore?
- Has thanked: 12 times
- Been thanked: 39 times
Re: Which version is it in PlayStore?
@Dan
Yes, I did join beta, and that's why it says "beta" in PlayStore. That's clear.
What I wanted to know:
At the same time it says 6.0.17 as version number in PlayStore ... so is 6.0.17 the version number of the beta version or is it the version number of the final version which was offered BEFORE the beta version.
- Has thanked: 1513 times
- Been thanked: 1038 times
If you've signed up for the Beta program, you will always have access to the latest version available. In this case, that version is 6.0.17, which is not a beta version.
