Agenda View in WinEPIM in the same Layout as under Android
Dualuser
Post by Dualuser »
The Android app has a splendid Agenda View, which has been lost on the Windows side.
It would be great, if you can implement it on the Windows side and make it printable.
The current table mode is close to useless because it generates a gigantic table with many empty boxes.
There is currently no mode to print all information out.
Thank you!
Has thanked: 1525 times
Been thanked: 1045 times
Re: Agenda View in WinEPIM in the same Layout as under Android
Thanks for the suggestion, noted. As for now what you can do to table in WinEPIM is to hide the fields you don't need and then print it out.
Dualuser
Post by Dualuser »
it would be really helpful to have in EPIM PC additionally an Agenda in the usual form, which could be copied into a word processor or another application:
- Begin - End
- subject
- other selected filed
There are many production sites, which do no allow mobile or other devices with a camera on their site. You need a printout for this occasion.
Furthermore, if you need to copy calendar data in a kind of reporting, this would enable it.
Alternatively, enabling sharing of selected dates to the clipboard in the android client would allow an efficient further processing too.
Best regards Dualuser (Android PC)
In WinEPIM, you can select and copy events in any of the Calendar's views. Is this the feature you were looking for?
