Main EPIM Window; Password section...
All the info in the Notes is now on a single line.
When you select the item and open it in its own window, the info is as it should be on multiple lines as it was originally created.
Bug in 11.8.4
- Has thanked: 1428 times
- Been thanked: 993 times
Re: Bug in 11.8.4
We're unable to confirm this issue. Please check if it still occurs for the newly created test password entry containing multiple lines in its notes field.
- PeCe
- Has thanked: 101 times
- Been thanked: 331 times
Re: Bug in 11.8.4
Using 11.8.4 portable pro version I could partially reproduce this. But unfortunately the problem is not consistent. Out of may 15 tries I saw this problem 3 times. Of one of these occurrences I made pictures.
The first is the password entry note preview with everything on one line. The second picture is the properly formatted pasword entry note displayed in an opened window. What I saw is that it occurs when the notes section is not on screen at first, but has to be shown by scrolling.
Also it only occurs after switching between modules.
As soon as I change to another password and then back to the "problematic" displayed password entry the note shows correct.
I created a new database file, entered a few items in different modules and tried it there. But in maybe 15 tries the problem did not occur.
Re: Bug in 11.8.4
PeCe, thank you for providing us with such a detailed description of the problem. We will review it once more on our end.
