IMPROVEMENT: Tap on contact details to copy them into the clipboard
eddie_s79
Has thanked: 16 times
Been thanked: 10 times
Post by eddie_s79 »
Android: 14 | EssentialPIM Pro: 6.0.17
Situation: I wanted to forward an email address out of the contact details view. I hold on the email address field, but nothing happened. So I had to edit the contact, to be able to select the mail address and to share it to the messenger of my choice.
  1. open contact view
  2. open one contact
  3. tap and hold to a contact detail field (e.g. email address)
  4. you can't copy or share it
If you tap once on the email address, popup opens with suggestions for mail applications (but nothing else).
IMPROVEMENT: Implement mechanism to copy detail fields into clipboard by tapping (holding) 2 seconds onto specific field (was my expected behavior)
Has thanked: 1424 times
Been thanked: 990 times
Re: IMPROVEMENT: Tap on contact details to copy them into the clipboard
Thank you for the suggestion, it has been noted.
