I don´t know which version this started, I just noted it today, in V11.2: When I insert an image to a note, I first search for images, open it with Irfan View, optimize it, save it > insert it in EPIM.
Today, I noticed, that picturesize in IrfanView (100%) is not identical with picturesize in EPIM. I jumped to: Image/Properties/Size: 61%. But the zoomfactor in Notes is set to 100%. Shouldn´t a zoomfactor of 100% show a picture with size 100%?
This 61% for this one picture is exactly the size it fits on my screen when the note is NOT open in its extra-window. That is ok, I expect this behaviour. But, when I doubleklick and open the extra-window for the note, I expect the picture to extend to its real 100% size!
How to see all pictures in original (100%) size? Size% is different for each picture!
image size
Re: image size
It seems to ba a bug in 11.2: Pictures added before, expand to 100% when opening extra window, pictures added today (just installed V11.2) will not expand to 100%
- Has thanked: 1424 times
- Been thanked: 990 times
Re: image size
This isn't a bug, this is a feature if you have Word Wrapping (Ctrl+W) enabled.
Re: image size
I noticed some kind of (strange) connection with word wrapping. But, if I open a note to an extra window, and there is no text to wrap- why are pictures wraped to 61% of the imagesize (in this case), when this 61% picture not fills the window from the left to the right border? 100%, or perhaps 90% would exactly fit in the window, so why making it smaller?
For text it is reasonable to trim lines to windowssize, but why make images smaller than necessary?
Re: image size
Some of the users didn't like they needed to scroll to see the whole image, while having the "Word Wrapping" option enabled.
Re: image size
Very nice feature I like embedding full sized images into EPIM for archiving but prior to this is was a huge hassle now it's a drag and drop experience.
Re: image size
What could be causing the discrepancy in picture size between IrfanView and EPIM, particularly when the zoom factor in EPIM's Notes is set to 100%? How can I ensure that all pictures display at their original (100%) size in EPIM?
Re: image size
Right-click on an image and select Image -> Properties -> Size.
