When in sticky notes it's nearly impossible to tell which Leaf you're in, unless you click leafs until found.
Could you please make it easier to know which leaf is selected?
Make Leaf tabs more visible.
- Has thanked: 9 times
- Been thanked: 51 times
Last edited by VictorParkerPIM on Thu Feb 08, 2024 7:54 pm, edited 2 times in total.
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Make Leafs more visible.
Your suggestion is appreciated and duly noted.
Thanks for the reply, and thanks again for moving my post to the correct place.
