If a task is currently copied and pasted, it will be pasted in the same place.
I work with the grouping via the task start and often have to copy tasks over several days. Therefore it would be helpful if the task is pasted into the group that is currently in focus.
Copying tasks
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Copying tasks
That's how it works on our end. If it functions differently on yours, please create a short video demonstrating the issue. This will help us ensure that we accurately reproduce and understand the problem.
Re: Copying tasks
Understood, thank you. We will look into the matter.
Re: Copying tasks
This is by design, and so far, there are no plans to change the current behavior, unfortunately.
