Android version contacts section
mevlutkalay
Has thanked: 6 times
Post by mevlutkalay »
Hi
1 - Android version. In the Contacts section, groups should appear as a tree. Can you fix this situation? Groups with the same name are a problem because groups are sorted by name. Let it be the same as in the Windows version.
2- Can the share option be added to the People section?
3- Can information for long names be shown in two lines in the Contacts section?
Thank you. I hope the translation was understandable.
Has thanked: 1424 times
Been thanked: 990 times
Re: Android version contacts section
Thank you for the suggestions, they have been noted. Regarding point number 2, you can select a contact and choose Copy, which could be a workaround solution at times.
