EPIM hangs on PC restart
Re: EPIM hangs on PC restart
I already did because I run EPIM on two laptops. Same problem on both computers.
Will the same error occur if you try to create a new database on the Portable version again?
- Has thanked: 17 times
- Been thanked: 43 times
No, I had this on the third PC, I bought even full business licence for one year for the new employee, and actually never used this. Lost money.admin wrote: Sun Dec 10, 2023 12:19 pm 1. We would like to ask that you avoid creating multiple separate posts. Instead, if you have new information that could assist us in resolving the issue, we encourage you to update your latest post. This helps to streamline the communication process and avoid duplicate information.
2. It seems that you are the only one experiencing these issues at the moment. When you attempted to run the Portable version, did you try using a newly created database file? If not, we would appreciate it if you could try that and let us know the results.
Reported.
Replies: we don't have that problem.
Win 10 Pro 64x
Win 10 Pro 64x
