11.7.1 downloads 11.7 on homepage
poet-man
Has thanked: 13 times
Been thanked: 44 times
Post by poet-man »
Hi there,
on my side, download and install of 11.7.1 presents 11.7 after start of program
Anybody out there with the same experience?
PeCe
Has thanked: 101 times
Been thanked: 348 times
Re: 11.7.1 downloads 11.7 on homepage
Post by PeCe »
Nope, I can not confirm this. I just downloaded the new version from the homepage.
Installed the portable version and it shows 11.7.1
poet-man, I would recommend trying to download the file using a different browser. It's possible that your current browser is getting the file from its cache, which could be causing the issue. Give it a try and let us know. Thanks.
poet-man
Post by poet-man »
I usually use Microsoft Edge. After deleting cache manually, I was able to download 11.7.1.
As this is not the first time, I had this problem, might there be a possibility, that the link on homepage can be set in a way, so it downloads file from source and not from cache or is this something to set in options of browser?
There is one possible solution that I can think of, which is to clear the browser's cache. However, normally there shouldn't be any issues with downloads.
poet-man
Post by poet-man »
Well, thats what I did! At least I know now, what to do in future, if the issue comes up again.
As this is something others described here as well in past, maybe the real reason will be discovered somewhen
