Hello
I added an ical (subscription) link to epim via the booked plugin WordPress. It syncs well with the computer, but I cannot sync this appointment with the Android phone calendar. I have the business version.
How can this be solved?
Marco
ical appointment dont synch with andriod phone
- MarcoMoens
- Has thanked: 1424 times
- Been thanked: 990 times
Re: ical appointment dont synch with andriod phone
If you go to Tools->Options->Synchronization and then click on your Android device name, you will find a setting that allows you to choose which calendar to sync with Android. I hope this is what you were looking for. Thank you!
