Hi
Windows version and android version sync error.
How can I fix the error solution.
Sync Error
- Has thanked: 6 times
- Been thanked: 3 times
- Has thanked: 1426 times
- Been thanked: 993 times
Re: Sync Error
What are the version numbers of your EPIM for Windows and Android? Additionally, we will need the sync log file. To locate the file, please follow these steps: Go to Tools -> Options -> Synchronization, click on "Browse..." and look for a file with a filename starting with "Android".
Re: Sync Error
Windows Portable 11.6.6
Android 6.0.14
This issue is caused by the notes section.
I sent the files
Thank you
Android 6.0.14
I sent the files
Thank you
Re: Sync Error
This is how the first error occurred.
It gave the synchronization error as in this picture.
Database - Android - I cleared pairing data.
Error again.
The error in the first picture I sent occurred after this step.
Error again.
Error again.
Error again.
Re: Sync Error
Thank you for providing the log file. We will work on resolving the issue based on the information in the file.
Update: The issue will be resolved in the new version. In the meantime, if you synchronize your data with the new database using EPIM Synchronizer (https://www.essentialpim.com/features/f ... nchronizer), the error should no longer occur.
Re: Sync Error
This error occurs again and again, usually after installing new versions with a changed database structure or in the case of errors in the database, which can have various causes.
Re: Sync Error
Which error are you specifically referring to?
Re: Sync Error
Windows 11 (22H2) - EPIM Pro 11.6.6
I haven't installed version 11.7 yet, because it still contains too many bugs.
Basically I have problems with the synchronization with AEPIM and currently error messages occur regularly during the synchronization of the notes. By constantly repeating the synchronization with intermediate closing of EPIM succeeds after several attempts a synchronization without errors. With the next Android or Windows version, however, the problems may reappear with other modules. In the forum, the synchronization problems of EPIM are also a constant topic. After a synchronization problem has been solved with a new version, a new problem appears in another place.
Re: Sync Error
To better understand the specific error messages you are encountering during synchronization, please provide a detailed description of the error messages and their screenshots.
