Two copies of AEPIM are running
marmegint
Post by marmegint »
Sometimes two copies of AEPIM are running (two windows appear on the display) and both do not always work properly.
Can two windows appear or is this an error?
My phone is:
AEPIM v6.0.11
Andoid 9, Build 55.0.A.10.26
Sony Xperia 1
Thank you.
Has thanked: 1424 times
Been thanked: 990 times
Re: Two copies of AEPIM are running
This is normal, and we hope it isn't causing too much inconvenience for you.
marmegint
Post by marmegint »
Hello!
The two windows were not a problem, and could even be useful if they worked properly.
The problem is that one of them doesn't always work, you can't use it.
Also, I don't know how to display both windows at the same time.
There are times when I work in AEPIM and tap the launcher icon again and there is still only a window.
Other times, after a little work, two appear.
The appearance of the two windows seems to be accidental.
So one of the mistakes here is that it doesn't always appear and you can't know why it appears.
The other error is that one of the windows is not always usable.
What is a bigger problem is that the application can be opened with a password, but when the display is later unlocked, AEPIM and its contents are also visible among the last used applications. Even if it has one window, and even if it has two windows.
When AEPIM is selected or tapped, it asks for a password to open and edit it, but before that, the password-protected application allows you to see everything and read data.
This is a major security flaw.
My phone is:
AEPIM v6.0.14
Sony Xperia 1
Thank you.
Thank you for bringing this matter to our attention. We appreciate your feedback, and we will thoroughly examine the situation to identify areas where we can enhance the process.
