Export .ics event
- Has thanked: 3 times
- Been thanked: 2 times
Export .ics event
I would like to see a way to export a single event to a .ics file. Mostly I want to be able to highlight an event and create an ICS file of just that event to share with others.
Thanks for a great program!
How do we change the world? ARK --- one Act of Random Kindness at a time -- Evan Almighty
Re: Export .ics event
That's already possible. You need to select an event, then click on File->Export->Calendar->iCal (ics) and choose the "Selected" option in the opened dialog window.
Thanks; That worked. I was using ver 10 and this feature is only available on ver 11. I didn't upgrade to latest version because my first attempt was a DISASTER! Some things disappeared, some were mangled, the calendar was split in two between the Android calendar and the PC calendar. I tried again recently after doing complete backups and the issues I found were minor and easily fixed. This database is VERY old and started with version 4.
