For the first time ever, I just tested syncing contacts between AEPIM and Google (using AEPIM 6.0.13).
But when I create a contact in AEPIM and then sync contacts with Google, the new contact does not appear in my Google contacts.
Is there a limit to the amount of contacts that ...
... AEPIM can handle?
... AEPIM can sync with Google?
Because strangely enough I have to do a search in AEPIM Contacts before I can see the new contact - it does not appear in the list of all AEPIM Contacts automatically.
FYI, I have 1.381 contacts in AEPIM.
AEPIM doesn't sync contacts with Google
- Has thanked: 1428 times
- Been thanked: 993 times
Re: AEPIM doesn't sync contacts with Google
I can confirm that there are currently some issues with synchronizing contacts with Google. We will address these issues in the next version update. Thank you for letting us know.
