11.6 has a lot of blank submenus and options
__fred__
Post by __fred__ »
Hi all:
Everything is in the subject I guess, except that it's the french version so the issue might be in the bogus translation (which seems to be really old from the header) Anyway, is there a way to force a different language at runtime? I tried renaming the language file but with no luck.
Screen Shot 469.PNG (9.56 KiB) Viewed 1729 times
Thanks in advance,
Cheers,
Re: 11.6 has a lot of blank submenus and options
French appears to be working correctly on our end. It is possible that the language file in the Portable edition did not update properly on your side. To resolve this issue, we recommend reinstalling EPIM into a different folder.
__fred__
Post by __fred__ »
Bingo! Reinstalling it in another folder solved the problem, thanks!
