New 6.0.12 Version still 6.0.11
I downloaded EPIM 6.0.12 from the EPIM page- I have no Google account. It says still 6.0.11 instead of 6.0.12!!??
- PeCe
- Has thanked: 101 times
- Been thanked: 329 times
Re: New 6.0.12 Version still 6.0.11
Today I have the same experience, downloaded 6.0.12 from essentialpim.com website and the app remains showing 6.0.11
So far Google play did not show an update to 6.0.12. Google shows betatester and 6.0.11
Also as far as I have checked, I do not see new options or u translated lines.
- Has thanked: 1418 times
Apologies for any inconvenience caused. Please try redownloading now and let us know if the issue persists.
Please note that the new version is released in stages through the Google Play Store. Thank you.
- PeCe
yes, new download and install from the Essentialpim.com website now shows 6.0.12
- Has thanked: 10 times
- Been thanked: 31 times
On my side I had a look into PlayStore (two days ago). There it gave me the possibility to update AepimPro, which I did and had 6.0.12.
Hi!
Please help me!
The version 6.0.10 is 26,7 MB (28 066 298 byte).
The version 6.0.11 is 26,7 MB (28 066 298 byte) too.
And the version 6.0.12 is also 26,7 MB (28 066 298 byte).
This is correct?
Please help me!
This is correct?
It probably is, the size of the APK file wouldn't matter much.
