Hello, I would find it very helpful to also use the option of "quick filters" for the tasks. For example, to filter for only open tasks or tasks with high priority.
Greetings
Filter as for notes
Re: Filter as for notes
There is such an option for tasks. Make sure to enable the Smart Lists option by clicking on the View menu.
If you're using a Portable version, please make sure you have the latest language file installed.
Which tasks do you consider to be "open"? Are they the ones that are not yet completed? If that's the case, you can always hide the completed tasks, leaving only the remaining ones displayed.
- Has thanked: 14 times
- Been thanked: 7 times
No, not a portable version. I have installed the 11.6 beta 2 completely via the installer.
Exactly, it's about tasks that are not completed, i.e. not ticked off. How can I hide the completed ones? I don't use the progress but complete the tasks via the tick.
I recommend reinstalling EPIM to resolve the issue.
To hide completed tasks, you can use one of the following methods:
1. Press Ctrl+H.
2. Click on View -> Hide Completed.
3. Right-click on the task list and choose Hide Completed from the context menu.
1. Press Ctrl+H.
