I use the notes to write down information during meetings. I also create tasks with the boxes to check off.
Now I have no overview of which tasks are still "open" in which note. Is there a way to search for them?
So that I get a list that only shows me notes that contain "tasks"?
Greetings
Searching for "tasks" within notes
- Has thanked: 1412 times
Re: Searching for "tasks" within notes
Do you mean you link tasks with notes through the "Related Items" option and then would like to see a list of notes that are related to tasks?
- Has thanked: 14 times
- Been thanked: 7 times
No, that's not what I meant. Within the notes it is possible to insert the checkboxes that you can then tick off, that's what I mean.
Attached is a screenshot.
I see now, thanks for the clarification. At the moment there's no way to search for such notes, unfortunately.
