Note search results sort?
lbw2112
Has thanked: 16 times
Been thanked: 10 times
Post by lbw2112 »
Is there some way to sort the search results in the Notes module on Android?
For instance, I have a journal with the date, etc. in the Title. If I search for "May 17" it pulls the correct results but they're jumbled by year, even though they're in the database in order. Like 2022, 2017, 2020, 2016, 2023 for example. I do use a Title format that sorts themselves in format 20230517 May 17, 20230518 May 18, etc.
Not a big deal but would be nice.
Thanks,
Larry
Re: Note search results sort?
There's currently no way to manually sort search results, unfortunately.
