Shortcut for Trees and Leafs
VictorParkerPIM
Has thanked: 9 times
Been thanked: 51 times
Post by VictorParkerPIM »
11.5 RC1
While working with several Tree Tabs I found that shortcut Ctrl+PgUp and Ctrl+PgDn moved from one tab to another, forward and back.
It doesn't not work the same in a Note with several Leaf Tabs, the shortcut skips every other Leaf.
I didn't find CTRL+PgUp and CTRL+PgDn mentioned in the help file or the shortcut menu.
Re: Shortcut for Trees and Leafs
We confirm this issue. Thank you for bringing it to our attention. We will fix it in the next update.
VictorParkerPIM
admin wrote: Mon Apr 10, 2023 10:39 am We confirm this issue. Thank you for bringing it to our attention. We will fix it in the next update.
Thanks!
VictorParkerPIM
11.5.1
In a Note the Ctrl+PgUp and Ctrl+PgDn moves from one tab to another since ver.11.5 RC2. "Great"
In the Tree sometimes it works and sometimes it skips every other Tab.
i7-8700 CPU@3.20GHz, Win11 Pro Ver. 22H2 (OS Build 22621.1635) 64-bit, 32GB Ram, 500gb M.2 SSD, 4Km, EPIMPro Life 11.5.1, Joined: Feb 02, 2010
