Font Issues
PamWiz
Font Issues
Post by PamWiz »
I'm using EPIM PRO 11.5 and running Windows 10.
I'm having issues with the font. My screenshot shows the issue in Arial but it seems to be happening with other font as well - but admittedly not all. It is better when using Calibri but I struggle with this font due to a vision issue (that's not correctable with glasses). Otherwise I wouldn't care at all!
Thanks much & have a super day,
Pam
Has thanked: 1411 times
Been thanked: 984 times
Re: Font Issues
Thanks for the report, that's a known issue. I'd suggest you to use some other font similar to Arial for the time being.
