I often get .ics calender files from apps or friends and would like to import them on Android. This does not seem to be possible. Can you implement this feature please
Thank you
.ics file import on Android
- Has thanked: 1406 times
- Been thanked: 977 times
Re: .ics file import on Android
Sure, will look into implementing the feature. Thanks.
- Has thanked: 2 times
The feature is still on our internal to-do list for implementation in future versions.
