Hi, I would really like to be able to import passwords directly from bitwarden (it also supports json format)
Thank you!
https://vault.bitwarden.com/#/login
Import password from Bitwarden
- Has thanked: 1419 times
Re: Import password from Bitwarden
You can always map which EPIM fields to import your data into.
