Hi there,
a problem which has been there some time ago and comes up now again ...
Trying to create a task in 6.0.10 via plus sign in calendar doesnot show date/time fields.
Why and how to solve.
No date/time fields in tasks
- Has thanked: 1418 times
Re: No date/time fields in tasks
This seems like a bug. We will fix it in the future versions of the app. Thanks.
- Has thanked: 10 times
- Been thanked: 31 times
Is there some way to workaround? Or how should I create a task?
Sorry, it seems I have misinformed you earlier. If you reinstall the app, the date/time fields should be visible again.
I will have a try.
However, this seems to occur, when all data in all modules is deleted (you remember the option in menu to delete everything), to sync AEPIM to epimcloud afterwards, to get all data again. After this the fields are not there anymore, when creating a new task.
Edit:
Reinstallation did it. So - it should possibly be found out, why it happens after purging all data without reinstalling
Ahha, now we know the cause of the issue, thanks! Will address it in the next update.
