Dedicated note attachments folder on AEPIM
RvH
Been thanked: 4 times
Post by RvH »
Hi, note attachments are stored in the download folder on Android. This folder might also be used for other files as well.
Is it an idea to store them in a dedicated EPIM attachments folder? Even better to let the user decide by means of a setting parameter.
Thanks for considering.
Rene
RvH
Re: Dedicated note attachments folder on AEPIM
Post by RvH »
Hi, 2 years ago I raised this suggestion. Unfortunately, I didn’t get a reaction.
Since I use the note attachments a lot, I retry this suggestion now.
I have several notes with attachments, like tickets for events and documents which I use on Windows as well as on Android. At this moment all these files are stored in the download folder together with lots of other files. It’s becoming a mess.
Please investigate if this suggestion can be included in a new (next) version.
Thanks!
Thank you, we'll review this and explore potential solutions.
