EPIM 11.2.5 — Copy/paste of tasks loses its place
DG
Beta Team
Has thanked: 16 times
Been thanked: 33 times
Post by DG »
In v11.2.5, pasting a copied task has taken on a new behavior. This is the sequence in a database that has more than 300 tasks:
1. Select a task
2. Ctrl-C to copy it
3. Ctrl-V to paste it in place, i.e. to have the copied task become a subtask of the original.
Result: EPIM pastes the item, but the cursor jumps to another task, forcing you to search for the one it just pasted.
Expected result: EPIM pastes and selects the task, so you keep your place in the list.
Copying and pasting a task works as expected in a small list where tasks fit in the main window. I also got expected results in 11.2.4.
Regards,
DG
Re: EPIM 11.2.5 — Copy/paste of tasks loses its place
Confirm this issue, will improve it in the next update.
DG
Beta Team
Post by DG »
More information. Upon pasting the copied note, EPIM returns to the previously selected task. For example:
1. Select and edit a task.
2. Elsewhere in the list, select another task, copy, and paste in place.
Results: EPIM returns to the task that was selected in Step 1. It seems the database pointer depends on the last edited task.
DG
Beta Team
Post by DG »
This is fixed in v11.5 Beta 1.
Thank you.
